Thanks for the application you are providing. It helps.
I have a minor feature request (meaning that I will certainly live without it, but it would be a nice-to-have).
I have 2 abyss devices https://www.modulargrid.net/e/abyss-devices-1u-to-3u-adapter-intellijel and would love to fit IN a few 1U modules. Currently the 1U modules I add are replacing the adapter and floating in the rack. The Adapter is moved somewhere else.
Feature request:
  • 1U modules can be added within the adapter
  • 1U modules could be rotated 90° (well, this is a pre-requisite for the above)
  • you could then move nicely the adapter along with the 1U modules attached to it.
G.
I would definitely second this request, now that I have the 1U external display for the Disting EX on its way to me.
GaryDelPonte
Request the ability to Rotate 1U - 3U modules 90° and be able to lay them above 1U Abyss Devices Adapter (Intellijel) https://www.modulargrid.net/e/abyss-devices-3u-to-1u-adapter-intellijel-silver-aluminum
-- NAUTILUS
@NAUTILUS : I do not understand the meaning of your message.
G.
I was just looking for this feature
jadehaze
Please this would be so useful.
So has this ever happened. It seems to have existed once but doesn't anymore per much older forum posts.
Also is there a comprehensive list of keyboard shortcuts somewhere. The one under help does not include the f = flip shortcut which does exist and works. The ability to rotate a module 90 degrees either directions would seem to be no brainer and would be extrememly useful. In addition the ability to include a module on the page and have it included in the stats even though it is not in the rack would also be useful. I do know people who literally hang modules by their power cable coming out of a space of a few HP because they do not have the space to mount it.
modulargrid
no, it did not materialise yet :(
On the rack planner page is a link called Keyboard Shortcuts. It lists all shortcuts. Also I have updated the help page, thanks for the hint!
It interferres with the Optimize Rack Space function calculation, but it might come eventually.
I see, but this is an "edge case". I recommend to just add another "fantasy" row the rack as workaround.
-- gcarr
Jukeshoe
An 'Ignore User' feature would be brilliant.
Thx for the consideration!!
Edit: pardon, this post should be in the general feature request thread, and is in no way a response to this specific thread/request...apologies.
― Friedrich Nietzsche
Sorry to revive an older thread but there is a function that used to work for me but no longer does that I think applies.
There are some options out there now to fit 1u modules into a 3u space. Previously i was able to simulate this by just 'floating' 1u modules in that space. They would often be ejected from the rack when revisited, but not I can't even place them in the 3u space.
Anyone else have this issue?
If what i did previously was again available that would be cool, but even better if it was set up to keep modules exactly where they are placed within the rack, that would be fantastic.
Thanks
