Hi folks
I have a Intellijel performance case gen 2 at home and i'm using an erica synth black sequencer.
What small sequencer would you recommend for a small 52hp 6U case for outdoor sessions and holiday?
Cheers NS
wishbonebrewery
If you are ok with chilled vibes, how about Marbles?
this forum seems so dead...
VONDENFUNKEN
just Pams Pro Workout
Noise Engineering Gamut Repetitor
Tubbutec Brains
Greetings
Chris
Thanks a lot :)
Slim
a Voltage Block would be a very versatile choice.
Pam's Pro Workout - can do everything you could possibly want from a sequencer
He_lium
Perhaps someting like Turing Machine (+expanders) or Rung Divisions
its not the smallest but i go for the qu bit bloom v2....
thanks for all your posts and help
cheers NK
Hey, steppy + turing machine seems like a good, quite performative. small footprint, combo. But it depends. what exactly will you be sequencing?
I vote AGAINST Pam's as a sequencer. One knob + 2 buttons (counting knob-push as a button) just isn't enough control for a decent workflow on a sequencer IMO*. I've used it as a srquencer with mild success, but it's just an annoying workflow and makes an otherwise-great module frustrating to work with.
*Well...Turing Machine only has 1 knob and zero buttons and I don't have a problem with that XD. But it's a fundamentally different workflow from Pam's as a sequencer.
Bloom isn't exactly small, but for what it gives you (3x quantized pitch, 3x gate, 3x mod sequences) it's awfully compact. Main issue I see is that if we're talking about a "Small case" then channels 2-3 may not serve much purpose. That might also just be my GAS talking after seeing it in two different threads today XD
Absolutely this:
Noise Engineering Mimetic Digitwolis
4 channels of quantized or unquantized CV or triggers or gates (or quantize incoming CV), very easy to dial in custom sequence lengths and to zero, randomize, or tweak on the fly. Incoming CV can be customized as to what it affects. Menus are colorful and easy to understand once you get your head around them. Takes a minute to understand how global settings effect everything but it's really a great module in 10HP, ideal I would say for sequencing for smaller cases.
has anyone plsyed with the Morphor 4hp sequencer? they look interesting and capable depending on the application. 4 outs from 4hp is pretty wild!
