Hi,
This is my recently assembled little rack. Using it mainly for ambient and more musical arps. Any suggestions for additional modules? Plan is to add more modulation, like some quad lfo or so. And attenuetors.
alt text
noodle_hut
Really nice.
Maybe add two or three Buff Mults to share those hard won signals.
As long as you're using the Arp, a 2hp Euclid always brings cheap thrills.
Hi ambientvalent,
If you post the link to the rack and not have it on private, it will show up on the forum as an image and interactive, so that we can see the module descriptions.
For simple attenuators you can use the Mixup and Amps modules that you currently have.
I think that if I owned this and wanted to make ambient, I would either add a second oscillator with a different flavour, or a second filter. You have a lot of nice utilities that have more 'modulation outs' available than you need for just the Atlantix. Most (self-oscillating) filters and oscillators can be slowed down far enough to work as LFOs as well.
Atlantix has two oscillators, a second oscillator module could complete a 3-voice chord. Or use it on it's own when you don't feel like Atlantix for a day. For different flavour oscillators you may think about:
- ALM MCO2, it has digital libraries like wavetable and physical modeling and a built-in filter and envelope and is only 6 HP. Most of its controls are in menus though.
- Famous Plaits in a 6HP clone version, has digital libraries and a low-pass gate. No real filter and there's only one filter in your system so far.
A second filter can be used on the second oscillator of the Atlantix, or use the Atlantix filter and the second filter in series or parallel. I would either choose something that can also track 1v/oct and self-oscillate so that you can use it as an oscillator+lfo, or maybe an Oberheim style state variable filter (which will traditionally not self-oscillate) as it can move between filter types fluidly, great for ambient.
If you stick to 6 HP, you can use that last 2 HP to get an extra utility of your choice in.
Hope that helps, good luck!
Thank you for the insights and feedback. Much welcome! I have this tendency to get stuck when it comes to the last pieces. An extra filter is a very good point and i think i'll go for https://modulargrid.net/e/intellijel-%C2%B5vcf (if i manage to get a hold on one) or https://modulargrid.net/e/doepfer-a-121-3 as well as one or two https://modulargrid.net/e/intellijel-buff-mult (already got a built in buff mult in https://www.endorphin.es/modules/p/2hp-power) depending on what filter choose.
(And yes, intellijel fanboy over here).
I would much prefer the Intellijel µVCF, as
  • Doepfer does not promise v /oct tracking.
  • The lowest Hz on the Intellijel is 2 Hz, meaning it cycles twice per second. That's fast for an LFO but still useable. 10 Hz on the Doepfer is steadily leaving LFO terrain.
  • Intellijel has attenuators for both FM inputs to create complex modulations or complex FM tones together with the Atlantix (bells, rudimentary DX7 epianos etc)
A resonant filter with a pitch decay envelope into FM and an amplitude envelope after the Filter Out is a great simple percussion sound. On deep cut-off it's a kick, half-way with some noise in the other FM it's a snare, and pitched very high with noise it's hi hats.
Here's a video on how to get some other shapes out of it
Thanks! Will most definitely order the µVCF today.
went for a bifold instead!
