a cool video :
If you need help with a module I own/sell, I'll be happy to help, don't hesitate!
it's 41hp not 40
Has anyone else had issues with the sensitivity of the touch pads on the Swarm? It only registers about 1 in 3 touches for me in use, unless I lick my fingers.
AEROCATONE
-- chrisormitch
Gross haha
It probably needs thouroughly cleaned after being all gummed up by human secretions.
I bet it will work like a charm after that.
Electric circuits and spit don't play nice together
over:under
-- chrisormitch
have just received the unit. same here, the sensitivity not working fine, sometimes it works most of the times it doesnt, im about to send it back to the dealer...
Yes, it's not perfect and unstable for a serious project, but is very experimental and give you the opportunity to search new sounds. I recommended use by midi and not manual if you search a better touch. For manual use is not stable and give you bad surprises when you are in record mode.
How did the return process go? I tried a couple times to get in touch with Eowave but they gave me the cold shoulder.
-- chrisormitch
-- unbalancedbeats
That's a great point. I tried a midi sequence into the Swarm from Live soon after I got it, and that worked well. The DAW was very new to me then so I didn't do more with that. I will try more midi things with it soon–been meaning to for months. Thanks!
Also, since I can't return mine as I bought it second-hand, I've been exploring best uses for it. I've found that when I think of it as a crazy drum machine, I get the most compelling and useful things from it and have the least "bad surprises".
-- pauperrasta
Sometimes i experimented static in my fingers to makes crazy the touchplates, to get a mini temporal solution i clean well the touch plates with a handkerchief with any substance and clean my hands. And sometimes is a little more stable to play with hands.
it's 41hp not 40
-- globalgoon
hm the one I owned was cleary a 40HP one, not 41, that's Y I created its page on here... I guess I'm not alone, apparently.
