Dear All. - Thanks at for opening the post and in advance for any advice.
I am new to Eurorack but not synths and hardware.
QUESTIONS below in bold.
I sequence using Hapax Squatp with MIDI + CV hardware synths to my DAW via Mixer. Ive got a Crap outboard compressor if needed.
I have used Softube Modular for fun FX racks but hate having to turn on the computer for FX
This my plan
SETUP: Direct Out from Synth Patchbay (in both Mono and Stereo!) to this rack for studio synths. (Super6. MS1. MonoPoly, Hydrasynth, TB3, TR8). CVS and MIDI from Hapax
PROPOSED CASE: Cre8Audio Nifty Case (saw Divkid use it. looked great for my size) Agree???
GOAL: To layer effects on Mono and Stereo synths. Fully expecting to record in per channel rather than run multiple channels of audio through this. Its for creativity, control and fun outside the box. i can always use Valhalla etc al in the DAW for static sounds in the final mix. I have a Midiverb for generic Verb. I want to modulate effects to get more movement in sound.
HAPAX provides options for CV step automation and LFOS and envelopes but id like to generate some of these internally hence the Abacus.
I wont buy the original Rings and Clouds but MomoModular do versions om Etsy that look great
So I have:
- VCA to adjust CV and or Audio signals? Do i need another for Audio out? I can adjust CV levels with Abacus
- Maths / Abacus. will try and get the original.
- Rings. love it. Having It
- Clouds. seems fun and right up my street sonically
- General FX. i just wanted a decent Reverb Delay module for general usage without going in the DAW. Any better suggestions
- Filter. Thus is Ripples but stereo. seems a winner to me?? Do you agree
- Mixer. Figure i wont want to do everything in series and also could blend input audio here if needed? ** Is this a good addition**
Any suggestions for other modules. key misses functionality wise
i feel so Freauency Mod might be a good addition?? Thoughts.
I have A Strymon Nightsky which I could swap for the Modular Starlab Id need to change case. it is space hungry so not sure whether i should bother. i think id prefer the workflow with Starlab but i'd need a bigger case
Thoughts?
if you made it thus far i hugely appreciate the effort.
noodle_hut
Here's a unique and terrible idea.
Drop the A-111-6 voice for an A-182-1 switch mult, and two 2hp pluck modules.
Yes, they are fussy to tune and a pain to rack straight, but often worth it.
You would get the stereo you're after plus a handful of polyphony.
The plucks will be fun with Maths, pair nice with Rings, and Clouds really likes them.
For what they are, they can sound wonderful.
You could really use that mult too.
And the Disting UI always frustrates me.
VONDENFUNKEN
For a FX rack better leave the voices out. As I understood you want to process your other synths.
I would keep the Ikarie and drop the rest for other stuff.
For Fx Rack:
-I like hands on modules like: Mimeophon as Delay, Reverb and Stereo-Feedback looper, all in one.
-Qu-bit Data Bender is nice for processing.
-Small and slow modulation sources like Divkid Ochd + Expander or NC Triple Sloths are useful
-Bastl Neo Trinity could be a good Modulation Hub for a rack of this size.
-Ikarie is cool for stereo filter, with drive
-There very small versions of rings and clouds, like nanorings and uClouds.
Greetings
Chris
Spring reverb is always nice in a hardware effects setup. Doepfer has a nice simple one.
You could also just get a Finegear Dust Collector to go with the rack, but that might be a little overboard.
Another option is a Poly Hector. It has Rings and Clouds in it plus a lot of basic effects, modulation, and routing tools that would take a lot of space in another rack. It's a touch screen, but it has a very effective interface that makes it easy to tweak and adjust.
I second that you should take out voices for an FX rack- if that's your intended purpose.
An unsolicited opinion for an addition that's hp- economic, the FX AID XL is a huge bang for the buck (6hp), though they might be hard to find new.
halbroome
-- lumpytapioca
I have 2 Plucks and liked them so much, I added a Bell, lol!
The tone of Plucks is so unique and shapeable.
Thank you all for your responses. I had slipped in a VCO as I made a patch I loved on Softube Modular and got greedy.
I realise - I want to be able to access and modulate what I have with ease rather than having loads of variables hidden in sub menus. Ivew got a Midiverb outboard for some generic backup hardware FX. So I ditched the Disting for starters.
After your comment and YouTubing I have revised to:
- Maths (Abacus - yes I know but I can afford it)
- 2 Plucks (TBC - but point noted above. This goes into the second round of buying)
- NanoRings - this all started as I wanted rings but no need for the full form factor. I like the CalSynth One
- Typhoon (Expanded Clouds Clone) - I realise I dont want to have to menu dive with Clouds so yes its lots of HP but as per comment above I either have it and enjoy it and have easy access or dont bother. I HATE MENU diving and sub functions.
- Ikarie - just seems brilliant
- Intelligel Sealegs - after much searching I just realised my favourite effect is always delay - plus the Reverb sounds good. Its alot of money and HP but I think its what I want and in many ways is the most creative effect when writing sequences.
I then have 8-12 HP depending on plucks. I will buy these first and see where I get but I feel I will need operators / mult / tools etc and just want to assess what first.
HAPAX has 4 CV and Gates Out plus the NiftyCase has 2 CVs + Gates so I can send LFOs / Automation and sequences from here.
I then think I will mix on my desk with seperate channels rather than summing in the rack.
Comments?
I really appreciate your guidance.
halbroome
I have found with 2hp modules -- like the Plucks -- that they are so thin and delicate (the backing comes off easily), that it is better to separate them with a four hp or bigger module. Also (depending on the separating modules) it makes it easier to tweak them, as the identical cables side to side make that difficult.
Otherwise, looks like you are in for some fun!
