Hey guys...
I’d be curious to know what else you would fill this case with. Which module(s) do you think would make sense to add to complete the case?
regards NoSky
Hey guys...
regards NoSky
That's what, 18 HP to fill?
I'm thinking:
Beehive (micro Plaits clone), 8 HP - Wavetable oscillator
Xaoc Tallin, 6 HP - 2 more VCA's with overdrive/distortion
Then pick some 4HP utility, maybe a Disting mk4, FX Aid, Divkid Trace or ochd...
You could save a little space by replacing the Line In, Line Out, and Headphones modules with a single Stereo I/O 1U. That will do the same thing but in 20 HP instead of 30. If you do that, and get rid of the 6hp blank, you can free up 16 HP of 1U space. You could then fit a Nonlinearcircuits Sloth Chaos & a Shakmat Tessitura Tailor.
I would choose:
Zadar is fantastic but you also need a fast, immediate and simple one. Dual function generator with vca's: Cosmotronic Delta-V - 10hp
Not to be used until you need something more. Almost anything: Disting MK IV - 4hp
An amazing 2 pole filter: 2hp MMF - 2hp
To add to keyboard cv, or mix waveforms: Joranalogue add 2 - 2hp
I'd say, experiment with what you've got until you feel the need for something, Its when you find you are limited in what you want to do that you realise what might be best to get next.
Think multiplication instead of addition.
Utility modules that multiply the value of the modules that are already chosen.
Nice voices on the top row. Probably enough for a while.
Maybe add a (sub)mixer on the end.
A Doepfer A-135-2 Quad VCA / VC Mixer would work nice there
and adds four voltage controlled VCAs too.
It could use a master clock. I like the Synthrotek M/DIV for that,
but it really wants a Pam's Pro Workout.
Then the sequencer doesn't have to step everything.
A Frap Tools 333 would let you combine, transpose, wobble, and share those note CVs
and also adds the mults it needs. Super handy.
