Please add Tube and Digital categories to this.
Thanks.
VCO with two vacuum tube based suboscialltors
http://ericasynths.lv/en/shop/eurorack-modules/by-series/fusieo…will there be a v2 without the need for the extra power supply?
-- mynoisecontrol
it does not need the extra power supply in version 1 either, it can be switched via internal jumpers to use regular eurorack power.
Actually, that's not all that bad a current draw, given what it is. For comparison, have a look at some similar Metasonix designs. As long as you're using one of the beefier P/Ss that are out there these days, especially the honkers in the new Pittsburghs, that should be just fine.
