wishbonebrewery
Discovering any Bugs? Post here!
-- modulargrid
There is a Lazy fly in our home office, its probably going to die as its that time of year.................
There seems to be a bug with My Modules feature. I've added quite a few (40-50), initially just three of them appeared in the tab. I logged out and back in, and then it seemed that most if not all of them were showing up. Then on following login just a single module is now showing up. Would be great to resolve this issue as it was one of the features that prompted me to upgrade to paying version. Thanks
modulargrid
-- soulsun69
If you go to the My Module section the search parameters still apply. Click Reset in the search form and check if the missing modules appear. Does that fix the problem?
wishbonebrewery
Not sure if something was just being changed but that 'Legacy Mode' button just showed up as a 'Toggle' button and the reply input form was stopping me use all of my letter keys, some worked and some didn't.
Weirdly now this seems OK again. Must have been a Glitch in the Matrix-mixer!
gimbalgambit
I don't know what the sparkles next to some manufacturers' names (like Xaoc Devices) mean, but in the module list they flicker incessantly on my iOS devices... is that intentional or broken? It is very distracting.
Bug report is for half-height modules in Buchla - I know they're more or less discontinued at Buchla, but there are still some third party manufacturers (Norhthern Lights) that do some.
Basically, the disorganization cat will sometimes show up, even though you half the half height modules in the right place, and save / reload of a rack will move them around, sometimes stacking them both at the top of the full unit, then mistakenly saving modules in the same slot.
eastwood
Not sure if this is a bug report or a feature request so apologies in advance.
Email notifications that I receive are following my browser/email client dark modes changing the text colour to white (or thereabouts) but the background remains white making the text close to unreadable.
modulargrid
-- eastwood
I don't know which email client you use but I have now deleted all color settings from the mail template so your client might work better?
Found some querying inconsistencies in the Module Finder when it comes to modules listed under the "Other/unknown" manufacturer:
  • go to Modules
  • as an example, type "corruptelam" in the Search box, don't modify any of the other search criteria
  • note how the module is not found
  • then select the "Other/unknown" manufacturer, now the module is found
  • feel free to try out with other module names (e.g., "fluxus duo"), you'll observe the same behavior
It seems the modules listed under "Other/unknown" are only found when you also select this manufacturer whereas expected behavior (by me) would be that these also appear if you just search on their name only and leave the manufacturer blank (-). Which is how it works for all modules that are attached to their actual manufacturer (e.g., I can search for "koszalin" and get the correct result even without selecting "Xaoc Devices" as the manufacturer).
-- drohn
"other/unknown" is excluded on purpose which makes sense to me.
There is a hint when you have 0 search results as well:
-- drohn
-- modular01
Ah indeed, honestly hadn't even noticed that yet. To me, it doesn't make sense if you enter the actual name of the module in your search criteria, but anyway: problem solved. Thanks!
-- modulargrid
The primary version of KOMA Dual Discrete VCA cannot be added to a rack. Choosing either version from the module page adds the alternative version picture. This started some months ago. Before that it worked fine.
Hello,
The font size on Microsoft Edge is too small for the entire website, almost unreadable. It looks like the website thinks my screen is huge, which is not the case. I am not sure if this is a bug or some sort of cache issue. But I haven't found anything in the cache. It used to work normally before, but something got broken. Any idea on how to fix it?
The font size on Microsoft Edge is too small for the entire website, almost unreadable...
-- electricfish
Ensure you have 100% zoom. I think the symbol in your address bar indicates a non standard value.
maybe you changed it unintentionally with Ctrl + mousewheel
common keyboard shortcut for 100 % zoom is Ctrl + 0.
those shortcuts should work in most web browsers
I got a big problem with how PedalGrid's homepage is set for my desktop resolution. Upon first load, it looks like this:
But when the window's width is shortened to this, it fixes itself?
It seems like the Mutable Instruments Plaits page has disappeard, although the module is still listed in the Module Finder.
https://modulargrid.net/e/mutable-instruments-plaits
modulargrid
-- Lovely_Listening_Aster
Thanks for reporting, should be fixed.
-- pawal
Looks good here?
-- pawal
Looks good here?
-- modulargrid
It was like that for at least a couple of hours (the only module I discovered it on), but I guess it fixed itself?
It happened again, Plaits is gone! But only when I am logged in, works very well when I am logged out. Mystery module page.
-- pawal
Can you reproduce the issue in a different browser or in a private browser session?
Try deleting all modulargrid.* cookies in the browser where you're experiencing the problem.
-- pawal
-- modular01
Same thing when I login in another browser that has never seen modulargrid before.
{"name":"Not Found","message":"Not Found","url":"\/modules\/find\/page:2.json?SearchName=plaits&SearchVendor=&SearchFunction=&SearchSecondaryfunction=&SearchHeight=&SearchTe=&SearchTemethod=max&SearchBuildtype=&SearchLifecycle=&SearchSet=all&SearchMarketplace=&SearchIsmodeled=0&SearchShowothers=0&SearchShowpanel=1&order=newest&direction=asc"}
modulargrid
-- pawal
What are you doing to get this output? Do you query the database manually? This is a json request that points to the wrong pagination page.
/page:2.json
There are not enough results for a page 2 so that is the culprit, it should read find/page:1.json or just find.json
Yeah, it looks like that is the problem. I can still replicated it when I am logged in, by clicking on Modules, search for "plaits", and scroll down to the bottom and click the Mutable Instruments Plaits module. Same problem when I am not logged in, and in another browser.
Using the direct link https://modulargrid.net/e/mutable-instruments-plaits also does not work, except when I use a browser I never used before.
When removing all cookies it works.
Logging in again, and search for plaits - exactly the same problem.
modulargrid
-- pawal
O.k. now I can confirm the problem. It has nothing to do with Plaits, it looks like the last module you click on a search page triggers that not found error. Might be related with the Show Blank Panels checkbox. Will look into it.
modulargrid
I have deployed a possible fix for the last module vanishing bug. I hope that solves the problem.
AEROCATONE
When rearranging my rack, I have noticed that when I swipe too far left (or right), the page "reloads" and reverts back to the arrangement from before I started the session. It has happened a couple times now. After it happens, I attempted to swipe both ways several times and the page continues to reload back to the same previous version. Any ideas?
over:under
AEROCATONE
Anyone else notice this? Is there a solution?
over:under
modulargrid
-- AEROCATONE
What device are you using?
AEROCATONE
-- AEROCATONE
-- modulargrid
Mac OS 10.14.6
over:under
This is my rack right now:
Whenever I refresh the page, the bottom left modules glitch out:
I can move them back into the rack, but refreshing the page messes them up again. I've tried this on macOS 15.1.1 in Google Chrome in incognito mode and it gives me this problem, it also persists onto my Ubuntu computer. I also have found that placing modules is generally pretty glitchy - sometimes I'll drop a module into an empty space and a nearby module will get booted out even if they aren't overlapping. I've dealt with this for a while now and always just assumed that the website was inherently a bit buggy, but thought I should post in case it's actually just me...
In my experience those issues have been present for years. This is a weird fix, but it usually seems to work: 1. Take the problem modules out of the rack and set them off to the side. 2. Put the modules back where you want them, but make sure the last thing they overlap before placing them is another module in that same row. If you overlap a module in a different row just before setting the module in place, it'll sometimes kick one of them out or be misplaced upon a page refresh.
-- Chace
That does work! Thanks for the tip.
-- modulargrid
there a quite a few 500 series modules missing in the database.
no blank panels and no burl b1d anymore
I'm consistently not getting a proper screenshot of my rack when I use the "copy screenshot url" button. I've tried to paste the URL in to different browsers and they all look the same, so I assume it's on the MG side. The image I get is one from weeks ago, instead of the current layout. I have a pretty large system with multiple tiers, so maybe that has something to do with it? Would be nice to get this working properly.
I'm unable to save profile settings due to having a three-character username . I've used this name on this platform since the very beginning. Can the minimum username length be adjusted? I'd just like to save my settings.
modulargrid
-- jvt
This should be fixed now.
Yay! It worked! :-) Thanks so much.
-- modulargrid
filterdrive
There's no way to report or take down duplicate versions of pedals, which also means there's no way to report malicious content, users, etc..
Might be an issue if MD evers faces an Eternal September situation, seeing as anyone can edit anything on here, just a thought.
I am encountering a bug with the "Copy Screenshot URL" function. I used that to get a screenshot of a rack so I could put it in a forum post. It worked so far, it gave me a link and the image looked correct in my browser and also in a preview window working on my post. I made some changes to the rack and then went to use the "Copy Screenshot URL" link again to get an updated image after making the changes. But now it doesn't seem to update. The link generates the same URL, and the image is exactly the same as before. The link still shows the first version of the rack, before I made edits. I make sure to force my browser to reload the link to make sure I wasn't seeing an old cached version and that doesn't seem to be the case. I forced a reload in my browser and it still keeps showing the old image.
symmetrizer
In my offers it look like I'm using a VPN but that is not the case. Is this a bug or due to my ISP (Bahnhof)?
I've noticed a different bug. Sometimes if I delete a module from a rack, or 'cut' it out using CTRL+X, the module itself will disappear, however that module's gray information window--the one that usually pops up when you mouseover a module--will remain on screen, moved to the upper left corner, and never goes away. Refreshing the page fixes the problem. I've tried to replicate the bug deliberately and I haven't been able to do so consistently, but it does happen sometimes.
